Hey there!
Have this problem only with connecting CDJ-2000 NXS2 to my Macbook M2. It doesnt display Time of the track (played and left) and Tempo. With CDj-900 it works great, but not with 2000. Does anyone have same problem or know the solution of this?
Browser works fine.
Browser works fine.
geposted Sat 11 May 24 @ 1:51 pm
Do you use the native mapper, or a custom one ?
Also, are you using the latest version of VirtualDJ or an older one ?
Last time I used CDJ2000NXS2 (about 2 months ago) the display worked fine as usual.
geposted Mon 13 May 24 @ 6:16 am
Yeah, native. My friend used it with same cdj2000nxs2 and it worked fine. But with my VDJ it doesn't work. I have the latest version of VDJ. Can it be related with the skin of VDJ?
geposted Tue 14 May 24 @ 8:46 am
I don't think that skin matters.
Also "Time" and "Tempo" are just parts of a bigger communication packet.
So, it's not a communication issue either, because in that case you would be missing a lot more things from screen.
Does the JOG RING move when you play a track ?
(JOG RING takes it's movement from time elapsed)
geposted Tue 14 May 24 @ 8:53 am
Yeah, everything other works great and sounds good, the only problem is displaying Time and Tempo. By the way BMP displays correctly
geposted Tue 14 May 24 @ 3:25 pm
Perhaps you have selected a pitch range that is not supported by the nxs2?
geposted Tue 14 May 24 @ 4:15 pm
I've changed it many times, but still not working. The most problem is Display Time...
geposted Wed 15 May 24 @ 11:47 am
Have you tried pressing the "TIME" button on CDJs themselves ? (It should toggle the display time between elapsed/remain/total e.t.c.)
geposted Wed 15 May 24 @ 5:56 pm
Sure, but still nothing
geposted Sat 25 May 24 @ 10:10 am
I've deleted all midi devices from mapping in settings of my mac, now Tempo is working, but Display Time still doesn't work... Have any ideas?
geposted Sat 25 May 24 @ 11:54 am
