I noticed that the "1 of 4" checkbox does not update when adding a new beatgrid section.
- When adding a new beat anchor, the option to force the beatgrid to start a new bar is disabled by default.
- If the previous anchor had this option set, the checkbox stays checked until you either click it twice, or select another beatgrid section and select back the anchor you just created.
I filmed the bug happening:
https://youtu.be/E8fbs_s2G9s
Have a nice weekend!
geposted Fri 24 May 24 @ 1:21 pm
Not a bug. User Mistake Not Proper Beat setting. See Manual beat Grid Instructions.
geposted Fri 24 May 24 @ 6:58 pm
