Hi,
Unless I'm missing something obvious, I seem to have a problem with Deck 1 of VDJ & my Denon Prime 4.
When I load a song onto deck 1 it automatically starts playing as soon as i move the deck 1 volume slider/fader up? its a pain, as I want it to start from the START PAD and not the slider/fader. Ive looked everywhere inside VDJ to fix this, ive even reinstalled VDJ to try and fix it but still the same. Deck 2 works as it should on the PAD. Can anyone help with this annoying problem?
geposted Tue 28 May 24 @ 8:33 am
Yes, search settings for
faderStart
faderStart
geposted Tue 28 May 24 @ 9:14 am
faderStart
faderStart
wow!! all fixed. Simple when you know how. Thank you so much
geposted Tue 28 May 24 @ 9:56 am
