Would anyone know how to change the mapping on the controller for buttons 1,2,3 for effects? See picture.
geposted Thu 30 May 24 @ 2:12 pm
It actually already has 2 options for those buttons, that you can switch between without any need for re-mapping
From the VDJ hardware guide for the unit:
Then it of course uses the fx that you select in the VDJ screen, either in 3fx per deck mode:
Or in 6fx mode:
Is that the change you are looking for?
Or in 6fx mode:
geposted Thu 30 May 24 @ 10:35 pm
No I want to directly link it to the button to the effect the one I want
geposted Sun 02 Jun 24 @ 4:21 pm
Essential mode...does not allow the effects. I want button 1, to be brake start, 2 to be echo fade out etc. Please advise.
geposted Fri 07 Jun 24 @ 3:46 pm
geposted Fri 07 Jun 24 @ 3:47 pm
Answered in a more descriptive thread
https://virtualdj.com/forums/259041/General_Discussion/Hercules_T7_controller_mapping_help.html
geposted Fri 07 Jun 24 @ 4:44 pm
