Hi, does anybody knows where does VDJ stores the settings for the skins? I have been using a skin called: V8 but by Fruit for some time now, and it was all good until couple of days ago the view of the waveform under the tracks became corrupted (bottom half of it turned black). I tried to uninstall the skin and then install it back, but the process just keeps the old settings intact. So how can I delete a specific skins settings? or reset that skin to default state?
geposted Sun 02 Jun 24 @ 4:28 am
Most skinners use variables to manage skin status, if you change to a default skin search options for
vdjScriptGlobal
delete everything there that should clear up the skin when you go back to it.
vdjScriptGlobal
geposted Sun 02 Jun 24 @ 5:11 am
Thanks LOCODOG for the fast reply,
when I delete everything in: vdjScriptGlobalVariables, will it mess up the library and all other settings in VDJ?
geposted Sun 02 Jun 24 @ 5:40 am
Won't effect the library at all,
it could effect some things [some 3rd party padpages/skins, you might have them you might not]
if you're really nervous, just use the restore from backup feature from before your skin messed up.
geposted Sun 02 Jun 24 @ 6:16 am
Thank you very much LOCODOG, your suggestion worked.
geposted Sat 22 Jun 24 @ 5:35 am
I upgrade to to VDJ2024 on my new computer and lost the skin for my controller Pioneer DDJ FLX6. Where can I find it in Virtual Dj?
geposted Tue 13 Aug 24 @ 12:59 am
There isn't a skin specific to the flx6.
geposted Tue 13 Aug 24 @ 1:09 am
I had downloaded one from VDJ a couple years ago. When I updated to2024 it disappeared. Thanks
geposted Thu 15 Aug 24 @ 2:04 am
Updating the software doesn't delete skins.
geposted Thu 15 Aug 24 @ 8:51 am
