I have no idea how to work this out or if this is even possible. I've noticed that the FX part select buttons on the FLX10 behave the same and effect all stems whether they are all enabled or all disabled. I think, for myself anyway, it would make more sense that no stem/part is has effects applied to them if none are enabled. Is there a way I can change this to work this way?
Or maybe an option could be put in with a future update?
geposted Wed 05 Jun 24 @ 3:20 am
