Hi, when updating to build 8184 I note the setting ”analyze on view” seems to set to yes since whenever I scroll in broswer it re-analyzing tracks.
Is there a specific need for this re-analyze?
Can I simply change the setting to no?
geposted Thu 06 Jun 24 @ 7:33 am
Maybe it's because the new features
- show cue points on waveform in browser column?
geposted Thu 06 Jun 24 @ 7:57 am
No change in my settings after update . It's off as before.
geposted Thu 06 Jun 24 @ 8:05 am
Nothing new, it's enabled by default if your computer is fast enough, and should only analyze songs that have not been analyzed before.
If it analyzes the same songs again it might mean that there's a problem storing your database
geposted Thu 06 Jun 24 @ 8:25 am
I was installing everything on a new laptop.
All files are copied exactly from source pc.
My thinking was all tracks in my db was previously analyzed.
But maybe I was wrong.
geposted Thu 06 Jun 24 @ 1:13 pm
