Hi all,
I'd like to enable the QUANTIZE feature ONINIT on the Pioneer DDJ-SX3.
I put quantize_all in the ONINIT script and it seems to work, but the problem is the Quantize button illumination state is now inverted. There is no LED_QUANTIZE in the mapping, so I'm not able to turn the LED on to match the state.
Is there any way to do this?
geposted Thu 06 Jun 24 @ 11:26 am
What you did works as intended.. kinda! (and that's why the LED is not working)
On the ONINIT key type & ( deck all quantize_all on )
Now restart VirtualDJ and it should work as expected.
geposted Thu 06 Jun 24 @ 1:35 pm
Thank you! That did it!
geposted Thu 06 Jun 24 @ 3:49 pm
Strong suggestion, if using deck all in an oninit script, wrap it in ( )
I've seen deck all over used in long oninit scripts and it resulted in 1000's of branches.
To see what I mean test this on a custom button
set $proof 0 & var_list & deck all nothing & deck all nothing & set $proof +1
versus this
set $proof 0 & var_list & ( deck all nothing ) & ( deck all nothing ) & set $proof +1
versus this
geposted Thu 06 Jun 24 @ 4:18 pm
Thanks Locodog, that's good advice.
geposted Thu 06 Jun 24 @ 9:15 pm
