When I have a track loaded to a deck and change stems from fully disabled to always, the stems engine starts but stems do not work. I have to reload the track for the stems to work. Is this normal behavior?
Also stems analysis on a 4 minute track takes 30 seconds whereas in Serato the analysis takes under 10 seconds for the same track. Setting in VDJ is set to use GPU which is NVidia GTX and I have 64 GB RAM so my PC is more than capable of handling stems. Why is VDJ almost 3x slower?
geposted Fri 07 Jun 24 @ 11:56 pm
all sounds normal
geposted Sat 08 Jun 24 @ 12:06 am
Higher fidelity stems, and unless you're bouncing round a track straight after loading, a few seconds for processing will have calculated a good section of the track round the playhead.
geposted Sat 08 Jun 24 @ 12:33 am
Ok thanks. Separate question. Whats the script to turn off the stem led pad when activated and have the led turn back on when stem pad is not active?
geposted Sat 08 Jun 24 @ 1:57 am
