I note during CDJ export function the waveforms are missing sometimes.
Track is analyzed before export.
Latest build.
Latest build.
geposted Sun 09 Jun 24 @ 5:44 pm
I have had that before and change the USB stick to a new Sandisk Extreme Pro and now it works.
I though my other USB was qood quality but it wasn't and that was the case.
geposted Mon 10 Jun 24 @ 8:20 am
I use high quality sticks
Sandisk pro extreme 128GB and 256GB
geposted Mon 10 Jun 24 @ 10:16 am
Is it random or related to specific Tracks ?
Happens on first creation of the USB CDJ Stick or after some edits ?
If you manage to reproduce with a minimum of Tracks/Playlists, please zip the entire USB stick and share.
geposted Mon 10 Jun 24 @ 3:46 pm
Ok Dad I will.
There are defenitely not often it happens, but I have seen a few tracks with the issue.
I will check more in detail.
One of the tracks I noted the waveform would come up in the RX3 at the same position the track was playing.
geposted Mon 10 Jun 24 @ 4:28 pm
I have seen a few tracks with the issue too after export the playlists for CDJ2000 Nxs.
Sometimes only a piece of the waveform is missing.
Tested with 2 pc's
If I export the playlist and load it into Rekorbox and analyze it there, it works.
Tested with 2 pc's
geposted Thu 10 Oct 24 @ 3:55 pm
