For anyone out there that has this controller can you tell me if the built-in stems work with Virtual DJ software? I'm thinking about getting this controller. Thank you
geposted Thu 13 Jun 24 @ 3:43 pm
It's the other way round, but yes stems work in conjunction with the controller assuming your PC is powerful enough.
geposted Thu 13 Jun 24 @ 4:16 pm
I do own this and they do work. Personally I find this controller to be a lot of fun as having four channels combined with stem splitting opens a whole new world of possible transitions and mixing.
geposted Thu 13 Jun 24 @ 7:30 pm
Do I need to download anything additionally to make it work (pioneer ddx-flx10) or will the controller work on it's own?
geposted Thu 13 Jun 24 @ 8:43 pm
So your controller (FLX10) controls the software (VirtualDJ) that is what does the stem separation. VirtualDJ has system requirements that determine if stems will work or not. Refer to https://virtualdj.com/wiki/Minimum+system+requirements.html > "Additional for stems 2.0" for more info.
geposted Thu 13 Jun 24 @ 8:47 pm
Check if firmware is updated to the latest version and also install the driver
https://virtualdj.com/manuals/hardware/pioneer/ddjflx10/setup.html
geposted Thu 13 Jun 24 @ 8:51 pm
Does the stems 2.0 virtual dj drivers need to be added also or will it work just from the pioneer controller alone?
geposted Mon 17 Jun 24 @ 6:11 pm
The stems are calculated within VirtualDJ and are nothing to do with the controller.
geposted Mon 17 Jun 24 @ 6:32 pm
There is no driver for VirtualDJ stems. VirtualDJ comes with the ability to do stem separation already included. Whether or not it can be done without the stems having been prepared in advance or if it can be done as soon as the track loads while it is playing depends purely on the capabilities of your computer hardware.
geposted Wed 19 Jun 24 @ 8:26 pm
Since you have this controller does the stems commands work properly on this controller? Thanks for your help.
geposted Thu 20 Jun 24 @ 3:01 pm
I mean it really depends on what you mean by that. They do work in the most basic sense of the default mapping can control stems. So yes, they work and if they don't in a way you need them too then very often it is possible to script your own solution.
geposted Fri 21 Jun 24 @ 3:54 am
