Hi! I was wondering if the "VDJ Sampler" could work like the "Traktor Remix Decks". basically the remix decks can play 4 samples at the same time of 64 samples in a remix deck, 4x4 samples per page of total 4 pages, plays only 1 sample per row, can Sampler work the same way?
I use the Remix Decks for playing piano/synth samples, not loops or beats btw so I really dont use Sync or Quantize features.
thank you for any feedback
geposted Mon 17 Jun 24 @ 7:30 pm
I think you may be looking for sample groups in VDJ. When you assign samples to the same group, VDJ will stop any sample in that group when triggering a new one within the group
Apart from that it really all about placing the samples in an order that makes sense visually in the sample bank and GUI, so that you don't get confused when using it
- and of course VDJ can have as many samples as you like in a bank - including exactly 64
geposted Mon 17 Jun 24 @ 8:15 pm
I had no ideia about that! I will take a look, thanks a lot Klaus!
does the VDJ Sampler always had that feature? (I was away from VDJ for a couple of years)
geposted Mon 17 Jun 24 @ 9:51 pm
Since the very first release of VirtualDJ 8, about 10 years ago.
geposted Tue 18 Jun 24 @ 12:19 pm
