Topic: Offline play unavailable - why???
When I try to play songs from my offline cache I receive a pop-up saying to connect to the internet and redownload the file - why is this place?
I can see the tracks in the offline cache.
geposted Tue 18 Jun 24 @ 8:07 am
The cache needs renewed periodically to check your subscription is still active.
geposted Tue 18 Jun 24 @ 8:08 am
How do I do that please?
geposted Tue 18 Jun 24 @ 8:13 am
szemekPRO InfinityMember since 2019
With right click on a specific track you should see "Refresh DRM" option.
You can also check if you have autoRefreshDRM = yes in Options.
geposted Tue 18 Jun 24 @ 8:19 am
Thanks but that hasn't worked - I'm refreshing DRMs on tracks that are in the offline cache but I'm receiving the same pop-up.
geposted Tue 18 Jun 24 @ 8:32 am
log out and log back in [right click your content provider folder.]
geposted Tue 18 Jun 24 @ 8:35 am
Give us a bit more info.
What service are you using? How long have the tracks been in your cache? Have you checked to see if the service still has the tracks available?
geposted Tue 18 Jun 24 @ 8:37 am
Thanks this appears to have worked.
geposted Tue 18 Jun 24 @ 8:45 am
