Is there a way to do this or does it have to be done manually?
geposted Tue 18 Jun 24 @ 1:45 pm
ctrl+click
shift + (click & click)
shift + (click & click),then ctrl+click
ctrl+a
many ways to select several files.
ctrl+a
geposted Tue 18 Jun 24 @ 1:52 pm
Thanks, however if you Ctrl + A a playlist containing a mixture of some tracks that are cached and some that aren't cached, there is no batch operation to download the tracks that aren't cached...
...not that I can see anyway.
geposted Tue 18 Jun 24 @ 2:59 pm
You can add the Browser field named as "File Type" in your Browser view.
Then sort by that and you will get all the "TIDAL" types together to batch-download to Cache
The files already cached will have "vdjcache" as FileType
geposted Tue 18 Jun 24 @ 3:46 pm
Amazing, thanks very much.
geposted Tue 18 Jun 24 @ 8:47 pm
