My VDJ is not picking up or reading my mixes. I was recording a mix finished it and when I went to analyze my mix it scanned it fast which I've never seen it go that fast. When I loaded my mix it was nothing but air and a straight line playing. Is anyone else having this issue? Also did the decks change to C and D? I just happen to notice on my screen that my decks instead of 1 and 2 it now reads C and D
Please advise if there is a fix for this
DjNandoC
DjNandoC
geposted Wed 19 Jun 24 @ 5:40 am
Depends a bit on your audio setup.
Guessing you have a "Record" entry in VirtualDJ settings, that records a silent input.
Try remove that record entry, if you are just mixing on the software internally
geposted Wed 19 Jun 24 @ 10:08 am
Where would I find that? I went ahead and deleted my software and redownloaded it to see what happens
geposted Wed 19 Jun 24 @ 2:16 pm
In VirtualDJ sound settings
If you are not getting any sound, check if you have a record (loopback) set to a line in with no sound.
https://virtualdj.com/manuals/virtualdj/settings/audiosetup/recordloopback.html
Are you using a controller/mixer? if so which one?
geposted Wed 19 Jun 24 @ 2:35 pm
