Anyone else experienced this? Using the mute vocal option in the track cleaner, occasionally it ignores the markers that I add, and continues to play the vocal through a section that should have been muted. No rhyme or reason for it - one 4-beat marker works as it should, then another 4-beat marker elsewhere in the song gets ignored. Very odd! Doesn't seem to be an issue when reversing instead of muting. Computer isn't struggling with processing stems, and you can turn instrumental on and off as fast as you like manually with no issues, it just seems to be an issue in the track cleaner.
geposted Wed 19 Jun 24 @ 5:00 pm
I found when using any censor operation, right after placing a censor sensor section, the playhead has to be moved back a few beats before the operation is audibly processed the first time. (e.g. I normally move it back about a bar). I haven't tried it out recently to know if the experience has worsened.
geposted Wed 19 Jun 24 @ 5:06 pm
