Hi There,
I bought a 2e hand Pioneer XDJ R1 and want to use Virtual DJ LE.
I used the code under my device to login but it says the code is already used by someone else.
Is there a possibilty to have acces to VDJ for free?
Thanks for your support.
geposted Sat 29 Jun 24 @ 5:31 pm
I believe those licences aren’t transferable which would mean buying a home licence to use with only that controller type or a pro license or subscription.
geposted Sat 29 Jun 24 @ 8:51 pm
Hi Philw,
Thanks for your comment.
I think that's the only solution yes.
I'll think about it ;-)
geposted Wed 03 Jul 24 @ 1:44 pm
