Hello everyone.
I have a problem. I have spent several days analyzing stems in various folders. I have created a folder on the external hard drive and addressed the stems to that folder. Everything was working fine until the weekend, which I took the drive with me and plugged it into another computer to play. Yesterday, I plugged the disk back into my computer and when I go into the folders, I no longer get the icon that the stems separation is complete on the tracks.
Any idea how to solve it? The folder is still there taking up a lot of space. This is the second time this has happened to me.
Thanks in advance for your help.
geposted Tue 02 Jul 24 @ 3:46 pm
Did you plug the hard drive back in after you opened VirtualDJ?
Make sure the HDD is plugged in & recognised in the OS before opening VDJ. I found that out a while ago.
geposted Wed 03 Jul 24 @ 7:44 am
Yes, I always connect the HDD before opening VDJ. So frustrating to had to analyze all files again. I think I'll leave it that way until a real solution is found.
Thanks for your post (Y)
geposted Sat 06 Jul 24 @ 7:20 pm
