I'm looking for help with a script I've used for many years that stopped working after version 2023-i b7607
For Left Deck:
Deck 1 loop_adjust 'move'
For Right deck:
Deck 2 loop_adjust 'move'
This script simply stops the platter in the Rane 12 and lets me use the platter to move (scrub) the set loop. I've used this script for many years with many different controllers, but for the last 5 years with the Rane 12s. Its very important to my workflow and video sets.
I appreciate any help to resolve this.
For Left Deck:
For Right deck:
geposted Thu 04 Jul 24 @ 2:07 pm
You should NOT include "deck X" on your script.
It should simply be loop_adjust 'move'
geposted Thu 04 Jul 24 @ 2:28 pm
Nope, It still does not work, and removing the deck x from the working version breaks the script. You must use deck x to make it work with the proper deck. I have 4 and they all work and have for over 5 years. The script command is broken in the code and does not work at all. This is a BUG.
geposted Sun 07 Jul 24 @ 5:58 pm
