i saw the below script in a post about a workaround for leaking crossfader,,,,
param_smaller 0 ? crossfader 0 : param_multiply 1.041666 & crossfader
is this for the specific leak areas or a general fix for all???
geposted Thu 11 Jul 24 @ 12:56 am
specific and really only a temp fix unless there's a consistent HW error.
geposted Thu 11 Jul 24 @ 7:44 am
This is a fix that worked for me on dials that don't quite centre on 0.5
I guess that would also work with the crossfader.
param_smaller 0.48 ? filter : param_bigger 0.52 ? filter : filter 0.5
geposted Thu 11 Jul 24 @ 9:54 am
@DJPhallus you could cut that down to
not that it makes much difference, but it tidies up "between" type queries.
param_bigger 0.48 && param_smaller 0.52 ? filter 0.5 : filter
geposted Thu 11 Jul 24 @ 10:37 am
For fear of going slightly off topic but....
doesn't work for reasons unknown? It filters out high but not low. Also..
filters low but not high?
param_smaller 0.52 && param_bigger 0.48 ? filter 0.5 : filter
geposted Thu 11 Jul 24 @ 8:40 pm
oh my mistake, I thought the implicit would get into the && query.
Something like this works, it's one query but more typing so not really worth the effort in this case, but if you understand it, it might come into play with something a bit more involved.
filter & param_equal `param_bigger 0.48 filter` `param_smaller 0.52 filter` ? filter 0.5 :
geposted Thu 11 Jul 24 @ 9:23 pm
