Where did the right click -> go to file location in explorer or delete the file go? Was it removed? Do I have to go out of VDJ to find the file in my computer in order to delete the song from the database now?
geposted Fri 12 Jul 24 @ 1:02 pm
In the File Operations sub-menu, just like it always was
geposted Fri 12 Jul 24 @ 1:03 pm
Its not showing up in my menu anymore. This is all I see now in the browser section. I looked in all the options to see if it was a setting that perhaps was off /on but didn't notice any. Thanks.
geposted Fri 12 Jul 24 @ 1:54 pm
Can you check the tag editor to see where the file is located?
geposted Fri 12 Jul 24 @ 2:23 pm
Yes. There are actually two locations atm and both do not have the option to delete the file. One is located on the local drive with the path to Dropbox and the other is directly to Dropbox showing up on the "Online Results" when I do a search for a song. I am still trying to figure out the whole dropbox cloud drive situation and have not figured out which drive to remove from the search DB while making sure i don't ruin my auotmix playlist edits. Thanks.
geposted Fri 12 Jul 24 @ 3:49 pm
