So while I can easily see where and how to add an Effect to the master output… shapes and changes the sound from all decks, I don’t see where or how to manipulate the effect. Are the Master Effect settings all “default”? I can see where and how to access the plugins settings for each deck, but not for the Master Effect. What am I missing??
geposted Sat 13 Jul 24 @ 10:25 pm
pull up the effect gui, dials can be added to skins with an edit.
Image shows video mixer panel, the 6 extra effects are video fx, but they are on non video slots [as there's only 1 video fx slot] so extra master fx slots with dials included.
same skin, master panel, added an extra master fx slot, and made the microphone fx slot visible.
geposted Sat 13 Jul 24 @ 10:43 pm
Thanks!
FINALLY noticed the little gear icon on the popups just like elsewhere in the GUI. I normally don’t use the Master Audio Effect, but if so, would only add something I don’t need to “tweak” constantly.
Got it!
Got it!
geposted Wed 17 Jul 24 @ 4:12 pm
