can you query when an effect is active and then map a custom button to do something while the effect is active?
I have a vst that has two buttons I want to map to the beat effects (controls effect_beats) bpm buttons but only while that same effect is active.
so that while vst is active & effect_beats is pressed it will do effect_button 'vst' 1 or 2
geposted Sun 14 Jul 24 @ 8:19 pm
Your question is too vague to give an example.
geposted Sun 14 Jul 24 @ 8:29 pm
