Topic: Skip, lagging issues
ladyd2uPRO InfinityMember since 2012
Can anyone direct me to links that will help with my current setup? Music is lagging in VDJ, Denon, Tidal as music source (using plan to stream). Been happening for over a month now, and I can not figure out why. Anytime I stream on Twitch or inworld Secondlife the entire desktop (windows 11) starts to drag. Lagging happens in VDJ, Denon, and Twitch/Secondlife. Fairly new PC. If I am not in Twitch (Secondlife) or using not using Denon VDJ works ok. Seems like there is some thing not updated or some setting(s) that may have to change. Just note I do have a lot of Tidal playlists (public/private), not sure if that is causing the issue. Help is appreciated. Thank you.
VirtualDJ Pro
Denon DJ Prime 4
Streaming Service Tidal
Twitch (with OBS)
Secondlife (using Firestorm-not latest upgrade graphic bugs in that version)
geposted Sat 20 Jul 24 @ 7:15 pm
