I have a launch pad that I use for my samples. I can't figure out how just push it one time to activate the sample. I have to push and hold to use that sample and all I want to do is hit it one time. It has to do with volume velocity. I want to turn that off so, all I have to do is hit it one time to activate. Also, is there a way to set it to that one sample and not have it work for all the samples on my launch pad?
Thanks, Dj Jimmy Ray
geposted Sat 20 Jul 24 @ 10:27 pm
The triggering mode can be set in the sample section (hold vs on/off)
Disabling velocity sensitivity differs for each hardware, so you should probably start by looking it up in the VDJ hardware guide for the unit
geposted Sun 21 Jul 24 @ 1:51 am
