How can I deactivate the Jog from "rotating" when I no longer touch it and the Jog no longer physically moves?
If I want to make a quick pitch bend, the jog wheel rotates with a time delay. This is extremely annoying
touchwheelbackspin: no
touchwheelforwardspin: no
touchwheelspinthreshold:100.0
Please help
Please help
geposted Sun 21 Jul 24 @ 9:05 am
Try setting the rampScratchTime to zero to sre if it helps.
geposted Sun 21 Jul 24 @ 1:34 pm
rampStartTime
rampStopTime
rampScratchTime
are already set 0.0
Do I have to change that?
rampStopTime
rampScratchTime
are already set 0.0
geposted Sun 21 Jul 24 @ 6:42 pm
I think the defaults for the start and stop ramp times are zero, but the default for scratch is 0.1 or something like that.
I'm not sure what controller you are using (is the jog touch sensitive, mechanical (CDJ like) or not?) but maybe the defaults should be left as is. There are other jog settings you can try changing to see if it helps (e.g. jogVibrationProtection), but make a backup of your settings.xml before you start doing that, so you have the behaviour that you have now to go back to if those tweaks don't work.
geposted Sun 21 Jul 24 @ 8:25 pm
My controller is a Pioneer DDJ SX3
geposted Mon 22 Jul 24 @ 5:00 am
