Hi All
Would love some help here as VDJ has only just started doing this! Say my track is 104BPM, when i load it in to a deck it will display as 104.36 or something similar, i have loaded the same song on both decks so you can see clearly that it does the same on both, i can't go and edit my 150GB of songs to show correctly, anyone had this before?
geposted Mon 22 Jul 24 @ 8:17 pm
104.36 is the bpm, just because the browser shows 104, doesn't mean it's exactly 104.
The browser could show 104 but the real bpm could be anything >103.5 to <104.5
A 1/3 of 1% difference is a rounding simplification.
geposted Mon 22 Jul 24 @ 9:02 pm
Oh right, that's odd because it's only just started doing this, it used to say 104 before when i loaded it on to a deck so i wonder if i accidentally changed a setting or something. Thanks for your reply
geposted Tue 23 Jul 24 @ 4:14 pm
