how to make the folder name sequence correctly with numbers in virtual dj
geposted Tue 30 Jul 24 @ 7:08 am
Right click on root (parent) folder and select "Reset sort order"
PS: When sorting TEXT with numerical values (such as folder names, filenames, e.t.c.) in VirtualDJ, the amount of characters that represent the numeric value does matter.
So, for TEXT fields with numbers, it will sort like this
Most likely in some cases you would want to add leading zeroes, so that it sorts correctly
As I said, this is valid only for TEXT fields.
Numeric fields sort properly
1
10
11
12
13
2
3
4
5
6
7
8
9
01
02
03
04
05
06
07
08
09
10
11
12
13
geposted Tue 30 Jul 24 @ 7:20 am
