Topic: VirtualDJ crashes when I click "REC"
This just started since last update. I haven't changed any of my settings, but now, whether I click REC from the main interface, or START RECORD from the settings, the program immediately crashes. The output folder shows a 0 byte file created.
Details: Windows 10; VDJ v2020-32 b8263; no controller; restarted program; restarted laptop; haven't done anything else until I see if I'm the only one.
Edit: only happens when output format is mp4. All other formats function fine.
Last edit: I just updated to v2024 and now all is well. I guess maybe next time I should check that first. D'oh!
geposted Wed 31 Jul 24 @ 2:25 am
tested build 8267 and confirmed. crashes without restarting while trying to record mp4 file -
first tested recording with audio loop and shader. immediate crash.
then tested with mp3 recording - recorded but choppy and said could not keep up.
tested same file and shader in 64bit version and recorded just fine.
geposted Wed 31 Jul 24 @ 4:17 am
hit record and crash with no restart still happening with 32bit b8280
geposted Fri 09 Aug 24 @ 11:06 am
Will be fixed in next update
geposted Sun 11 Aug 24 @ 1:24 pm
