Hallo, I'm missing some played tracks in the history. Sometimes they just don't get recognized and saved.
Can anybody help me, please?
geposted Sat 03 Aug 24 @ 5:20 pm
VirtualDJ waits a minimum number of seconds (defined by the option historyDelay, default = 45 seconds) before adding an audibly playing song to the history list of the session. Are you playing songs long enough for that to happen? If not could you try lowering the setting to see if it helps?
geposted Sat 03 Aug 24 @ 5:27 pm
Thank you! Yes, I play the songs complete from start to end, yet they on't appear in the history while others do. Most others.
geposted Sun 04 Aug 24 @ 1:35 am
Are you using the XDJ XZ ?
If so, you will need to enable Midi mixer from Utilities, so that VDJ is aware of the Vol and CF positions and better understand whick Tracks are played
geposted Mon 05 Aug 24 @ 12:21 am
