Topic: Buttons light up.
How do I make the effect buttons light up on my controller whenever I press it? I wanna press the effect button for slot one and have it light up on my Numark platinum fx controllers effect slot.
geposted Mon 05 Aug 24 @ 12:05 am
I have the echo or flanger mapped it lights up but if I try to use a virtual dj effect like slip brake it doesn't light up on the controller.
Well I guess nobody knows how to get this done?
I need help with this guys. If it's possible yes if not then no. I can't figure it out.
https://virtualdj.com/manuals/hardware/numark/platinumfx/layout/effects.html
Your controller does not offer effect buttons "per deck"
Therefore it uses a special mapping.
What you CAN do is to remap both the button and the LED of the button to substitute one effect with another.
So, you can remap FX_REVERB button to let's say deck all effect_select_toggle 'slip brake' and then remap the LED_FX_REVERB to deck left effect_active 'slip brake' ? blink : deck right effect_active 'slip brake' ? blink : deck all effect_select 'slip brake'
I Appreciate the help. You saved the day.
How do I not assign a certain effect name but instead put effect 1 effect 2 ....... And just have them work? I wanna use random effects in the slots.
Never mind I figured it out.
