I would like advice on running stems live
Would this configuration be adequate?
Intel® Core™ i7-12650H Processor
RAM: 16 GB / Storage: 1 TB SSD
NVIDIA GeForce RTX 3050 4 GB
If you using similar specs, your thoughts please.
geposted Mon 05 Aug 24 @ 1:27 pm
RTX3050 needs 6gb. That will be very slow.
I did look at that, it's says 6GB is best that's optimal alright
AMD Ryzen 7 7735HS Processor
RAM: 16 GB / Storage: 512 GB SSD
NVIDIA GeForce RTX 4060 6 GB
This is better then ?
geposted Mon 05 Aug 24 @ 2:17 pm
Apart from the fact that an Intel processor is better. But you're clearly working to a budget so there will be compromises.
geposted Mon 05 Aug 24 @ 2:29 pm
Thanks for your thoughts..
One last one..
RAM: 16 GB / Storage: 1 TB HDD
NVIDIA GeForce RTX 4050 6 GB
This maybe it.
One last one..
This maybe it.
geposted Mon 05 Aug 24 @ 3:00 pm
Yeah that's probably the best one.
geposted Mon 05 Aug 24 @ 3:02 pm
