Is there any way I can get an older download version. I haven't been updating it because I run an older version of Mac and I accidentally updated it and now it won't run on my Mac any more. Can you guys help me with that Please so I can get back to DJing I have Gig on Friday.
geposted Tue 06 Aug 24 @ 9:30 am
geposted Tue 06 Aug 24 @ 9:51 am
Those are just recent builds. All the legacy builds are no longer available.
https://www.youtube.com/watch?v=5a9BP7GGjeI
geposted Tue 06 Aug 24 @ 10:02 am
You can find the last build that works for your OS version here:
https://virtualdj.com/wiki/Minimum+system+requirements.html
geposted Tue 06 Aug 24 @ 10:19 am
Ah that must have been added to the download page. Thanks for the link for future reference.
geposted Tue 06 Aug 24 @ 10:30 am
With respect, he didn't ask for a legacy version - just for an "older" version.
He also didn't specify the OS version on his Mac, or the VDJ version he was previously using, so based on what he actually wrote, I provided a link to older versions.
@Adion is it not possible for VDJ to check OS before offering incompatible updates?
geposted Tue 06 Aug 24 @ 11:03 am
Normally these old os indeed don't get auto update, so perhaps it was a manual update
geposted Tue 06 Aug 24 @ 11:15 am
The oldest version on the link you supplied was 5th June. That's hardly going to work for "an older version of Mac" is it?
Anyway it doesn't matter as some legacy versions are now on the main download page as stated above.
geposted Tue 06 Aug 24 @ 11:31 am
I didn't bother checking the dates. I just provided the link, as that's the link most people are after.
Impossible to know, because (as I said) he didn't give details.
Is it possible to "accidentally" perform a manual update? I wouldn't think so. :-)
geposted Tue 06 Aug 24 @ 1:38 pm
If you download the latest version from the website and installed it, you manually updated the version you had previously installed.
geposted Tue 06 Aug 24 @ 2:21 pm
That's my point. You can't accidentally download it and then accidentally install it. Those are deliberate actions.
geposted Tue 06 Aug 24 @ 3:01 pm
Does it really matter? The issue is now resolved.
geposted Tue 06 Aug 24 @ 3:17 pm
We don't actually know it's resolved, because he hasn't been back.
The question remains, how did he manage to accidentally install an update that was incompatible with his system? If it was VDJ offering the update, that would be wrong - but Adion says it shouldn't.
Unless he posts again, we won't know for sure.
geposted Tue 06 Aug 24 @ 4:34 pm
