Started my radio before leaving home, added songs from my filter folders, enabled shuffle and repeat. Aaand it plays 2 songs in an forever loop. Pretty please fix this bug.
geposted Wed 07 Aug 24 @ 4:07 pm
Use AutoMix to listen to new tracks at times.. and have never experienced this.
Where did the track, "Mission Venice" come from?
It is NOT in your Automix playlist.
And seems that only 1 track was played from the Automix playlist.
I tired to reproduce, with automixDualDeck .. set to Yes and No. and could not..
and otherwise similar settings.
Maybe post screenshot of settings > options > cat:automix
to show all your complete automix setup..
since as you imply, it happens a lot.
PS
are there possibly, any POI scripts for those tracks ?
PS
geposted Wed 07 Aug 24 @ 4:46 pm
I can't provoke this error, and I use Automix during dinner at most gigs
I don't think there is a general bug
geposted Wed 07 Aug 24 @ 6:16 pm
No POI scripts. If the track "Mission Venice" is in automix playlist we don´t know since we can't see the whole playlist, and I use shuffle. It seems to happen if I have a song playing already and then just add new tracks and enable automix. This is the third or fourth time it happens now for me during the summer. And I use VDJ every day.
geposted Thu 08 Aug 24 @ 7:37 am
Does it work correctly if you use automix on one deck (the default way)?
geposted Thu 08 Aug 24 @ 8:30 am
I will use automix on one deck from now on and see if it helps, thx for suggestion. I forgot that 2 deck is not default.
geposted Thu 08 Aug 24 @ 1:02 pm
