I'm using the denon mc 4000 and noticed on my computer screen it shows my crossfader has a quiver on either the right or left side causing my songs to bleed into each other. The only solution I have found is to totally disable the crossfader. Am I missing something??
Thanks folks
Thanks folks
geposted Wed 07 Aug 24 @ 4:57 pm
Stick some switch cleaner in it to see if that stops it moving. It sounds like a hardware fault rather than software.
geposted Wed 07 Aug 24 @ 5:08 pm
don't full understand exactly, what you mean by "quiver".
Best to test the controller's crossfader,
When watching the crossfader values of the slider, in the settings > controller > mapping > upper right window/panel
it should go smoothly from 0.0 to 1.0 when moving from Left to Right.
geposted Wed 07 Aug 24 @ 5:10 pm
Thanks for the advice bought some spray and it's working fine now yeah
geposted Thu 08 Aug 24 @ 11:29 pm
