When I load a song in deck 3 the pitch gets automatically set to the maximum. For example, if the pitch range is 6% percent then the song is automatically 6% faster. This happens only with deck 3. Please help
geposted Fri 09 Aug 24 @ 8:44 pm
Check to see if you don't have any autosync options on for that deck (auto match bpm, pitch lock, beat lock, etc).
See the Auto Sync Options - potentially switch them all off.
geposted Fri 09 Aug 24 @ 10:29 pm
It also happens when all the other decks are empty. When I load one song in deck 3, it immediately jumps to the maximum of the pitch range value that is actually set. when I chose 6%, it jumps to 6%, when I chose 50%, it jumps to 50%. And only on deck 3... Really strange
geposted Fri 09 Aug 24 @ 11:14 pm
