Hi there,
i´m having a problem with backing up .vdjfolder files.
Virtualdj v2024 b8263 running on Windows11 64 bit.
in VirtualDJ i have a virtual folder "X" with 10 subfolders within, which should be backed up.
Therefore i usually backup all the files within the VirtualDJ Folder in the AppData folder on Windows.
On the root folder in "local > VirtualDJ > Folders >" there´s a Folder "X.subfolders". Within this folder
there are not all 10 subfolders, but only 2, plus the "order" file. The other subfolders, which exist
within the VirtualDJ program are not included. When i rightclick one of the missing folders, eg. "XX", and click on the preporties,
the path showed is "root:\X.subfolders\XX
actualy the missing files are not,where VirtualDJ shows, they are.
I can export them seperately, but that´s not practical for me.
where are the missing files, is this a bug, and how to backup properly?
geposted Fri 09 Aug 24 @ 9:00 pm
see the backup section on this page of the manual
https://virtualdj.com/manuals/virtualdj/interface/browser/toolbar.html
geposted Fri 09 Aug 24 @ 9:50 pm
If the files in the folders are on a different drive, the subfolders will be on that drive as well.
To backup all it's indeed best to use the backup feature within VirtualDJ, which will back up the lists from all connected drives
geposted Sat 10 Aug 24 @ 4:56 am
