when i want to listen to a sample in the editor i have no sound. I tried to find a solution in the support but cant find anything to help me. I have sound if i play a track or a sample from the sampler, no issue. only if i open a sample in the editor. I work, edit on my music without my controller and just use the laptop.
specs:
Operating System
Windows 11 Pro 64-bit
CPU
AMD Ryzen 7 Mobile 4800H 74 °C
Renoir 7nm Technology
RAM
32,0GB Dual-Channel DDR4 @ 1596MHz (22-22-22-53)
Motherboard
ASUSTeK COMPUTER INC. G713IE (FP6)
Graphics
Generic PnP Monitor (1920x1080@144Hz)
4095MB NVIDIA GeForce RTX 3050 Ti Laptop GPU (ASUStek Computer Inc) 54 °C
512MB ATI AMD Radeon Graphics (ASUStek Computer Inc)
SLI Disabled
CrossFire Disabled
Storage
1863GB Western Digital WD Blue SN570 2TB (Unknown (SSD))
953GB SAMSUNG MZVLQ1T0HBLB-00B00 (Unknown (SSD))
4657GB Western Digital WD Game Drive USB Device (USB (SATA) (SSD)) 59 °C
0B Seagate Backup+ Hub BK SCSI Disk Device (USB )
4657GB Western Digital WD Game Drive USB Device (USB (SATA) (SSD)) 57 °C
4657GB Seagate Expansion SCSI Disk Device (USB (SATA) )
virtual DJ v2024 b8280
specs:
Operating System
CPU
RAM
Motherboard
Graphics
SLI Disabled
CrossFire Disabled
Storage
geposted Tue 20 Aug 24 @ 8:57 am
The audio of the Sampler editor is routed to the "Headphone" output.
Where/how do you currently have your Headphone audio routed?
If output to the controller...
setup and use a different audio configuration, when the controller is not connected.
OR
one could, I guess, get fancy and script (to change) the audio configuration, differently when the controller is NOT connected.
by using apply_audio_config to apply the 2 different audio configurations.
in combination of setting a variable in both the controllers ONINIT and ONEXIT mapping, which would be used, to set your audio configuration dependent on the variables state.
OR
geposted Tue 20 Aug 24 @ 9:17 pm
audio is direct to headphone, the controller as said before is not in use.
geposted Mon 26 Aug 24 @ 1:21 am
found a solution, just set the headphone to channel 1+2 (same as the master) and i had sound from the sample editor
geposted Mon 26 Aug 24 @ 1:34 am
