Hello I need some help. Ive been practicing on my beat matching and mixing without the sync button. I have a r&b track that's 82.5 bpm and the other I'm trying to mix into is 93.0 on deck B. Let me ask this about the sync button say if I hit the sync and it auto matches the bpm so I can crossfader smoothly in the track but the song on deck B slows down. Then once I crossfade over to B. The song slows down then I have to push the tempo back up so it want be so slow. Is this Normal? Do I have to hurry up and push up the pitch slider so it doesn't sound so slow. Is this how mixing with the sync button is done? I know a lot of y'all don't use the sync but I'm now. I need some tips on this.
geposted Fri 23 Aug 24 @ 5:39 pm
I know the echo out effects works alright.
geposted Fri 23 Aug 24 @ 5:46 pm
There are plenty of tutorials online covering how to mix. There's even a thread on here.
https://virtualdj.com/forums/6288/Music_discussion/DJ_MIXING___basic_-_advanced_-_pro.html
geposted Fri 23 Aug 24 @ 7:26 pm
This helps out a lot. Thanks I've been reading up on it.
geposted Fri 23 Aug 24 @ 8:16 pm
