Hallo,
ich habe einen Denon Prime GO und nutze VDJ 2034.
Ich benötige einen neuen Laptop.
Welcher wäre besser geeignet und warum?
Intel® Core™ i5,i5-12500H Prozessor, 16 GB RAM
12 x 4.50 GHz
Intel® Iris® Xe
ODER
Intel® Core™ i7 Prozessor 1065G7, 8 GB RAM
4 x 1.30 GHz
Freue mich über eure Antwort.
Gruß
Daniel
12 x 4.50 GHz
Intel® Iris® Xe
ODER
4 x 1.30 GHz
Gruß
Daniel
geposted Sat 24 Aug 24 @ 7:06 pm
Keiner von denn 8GB Ram ist viel zu wenig und die Grafikarte zu schwach besser so was.
Prozessor Intel® Core™ i7-13650HX der 13. Generation
Betriebssystem Windows 11 Home
Grafikkarte NVIDIA® GeForce RTX™ 4060
Arbeitsspeicher 32 GB DDR5
Storage 1-TB-SSD
Bildschirm 16.0-Zoll-Bildschirm Quad HD+ (2560X1600) 240Hz
https://www.dell.com/de-de/shop/dell-laptops/sr/laptops/g-series/nvidia-geforce-rtx-4060?appliedRefinements=41503
Below are the recommended system requirements for running VirtualDJ:
Ideally, your computer should meet and preferably exceed the recommended requirements.
MS Windows
Supported Operating systems
Windows 7*
Windows 8*
Windows 8.1*
Windows 10 (Version 1709 or later)
Windows 11
Recommended Hardware requirements
Intel® i5™, AMD Ryzen 7 or better
Windows 10 or newer
Multi-channel soundcard
8 GB RAM or more
Additional for Video mixing
AMD™ or NVIDIA® video card
Dual-screen output for second monitor
Additional for Stems 2.0
Windows 10 64-bit or newer
NVIDIA video card (GTX 1050 or above with 4GB VRAM, RTX with 6GB VRAM recommended)
or AMD video card (Radeon RX 5600 XT or better)
macOS
OS X v.10.14 (Mojave)
OS X v.10.15 (Catalina)
macOS 11 (Big Sur)
macOS 12 (Monterey)
macOS 13 (Ventura)
macOS 14 (Sonoma)
Intel® i5™ or better, or M1 processor or better
macOS 12 or newer
8 GB RAM or more
AMD™ or NVIDIA® video card or M1 processor
macOS 13 or newer
Apple Silicon CPU (M1 or better) with 16GB RAM
Storage 1-TB-SSD
MS Windows
Windows 7*
Windows 8*
Windows 8.1*
Windows 11
Windows 10 or newer
8 GB RAM or more
macOS
macOS 11 (Big Sur)
macOS 12 (Monterey)
macOS 13 (Ventura)
macOS 14 (Sonoma)
macOS 12 or newer
8 GB RAM or more
macOS 13 or newer
geposted Sun 25 Aug 24 @ 7:33 am
Der erste hätte 16GB RAM.
Ich nutze VDJ lediglich zum Musik machen, keine Videos.
Wäre einer von beiden hierfür geeignet?
geposted Sun 25 Aug 24 @ 7:40 am
Und Real-Time Stems Separation 2.0 ?
Mindesanfoderung für Virtual DJ!
https://de.virtualdj.com/stems/
https://de.virtualdj.com/products/virtualdj/features.html
Deine ausgewählten Notebooks sind für Business und Studium geignet mit abstrichen ohne Stems, Video usw. würdes es gehen aber mir persönlich wäre das viel zu wenig und in einem Jahr wärst du vermutlich wieder am limit mit dem Notebook.
geposted Sun 25 Aug 24 @ 7:49 am
Vielen Dank für Deine Unterstützung. Das hilft mir sehr.
Kannst Du mir auch einen Laptop - für meine Zweckr - für unter 1.000 € empfehlen?
geposted Sun 25 Aug 24 @ 8:27 am
https://www.dell.com/de-de/shop/gaming-and-games/g15-gaming-laptop/spd/g-series-15-5530-laptop/cn22257
G15 Gaming-Laptop
Grafikkarte NVIDIA® GeForce RTX™ 3050
Storage 512 GB-M.2-PCIe-NVMe-SSD
Display 39,6 cm (15,6")-FHD-Display (1.920 x 1.080), 120 Hz, ohne Touchfunktion
16 GB Ram erweitbar
899,00 €
G15 Gaming-Laptop
16 GB Ram erweitbar
899,00 €
geposted Sun 25 Aug 24 @ 8:36 am
Könnten Sie mir evtl. nochmal Ihre Meinung zu folgendem Laptop geben?
https://www.mediamarkt.de/de/product/_lenovo-v15-g4-or-156-or-i5-13420h-or-8-x-460-ghz-or-notebook-mit-156-zoll-display-intelr-coretm-i5intel-i5-13420h-prozessor-40-gb-ram-2000-gb-ssd-intelr-uhd-graphics-black-windows-11-64-bit-143326940.html
geposted Sun 25 Aug 24 @ 10:53 am
[quote=metrix]
Mit dieser Grafikkarte funktioniert Stems 2.0 nicht !!
geposted Sun 25 Aug 24 @ 11:47 am
geposted Sun 25 Aug 24 @ 12:29 pm
geposted Sun 25 Aug 24 @ 12:31 pm
Habe noch einen gefunden
https://www.mediamarkt.de/de/product/_hp-victus-gaming-15-fa1365ng-gaming-notebook-mit-156-zoll-display-intelr-coretm-i5-i5-13500h-prozessor-16-gb-ram-1-tb-ssd-nvidia-geforce-rtxtm-4050-silber-windows-11-home-64-bit-2918385.html
Bin da leider nur Laie und freue mich über eure Antworten.
geposted Sun 25 Aug 24 @ 1:13 pm
Benz Werner wrote :
[quote=metrix]
Grafikkarte NVIDIA® GeForce RTX™ 3050 Mit dieser Grafikkarte funktioniert Stems 2.0 nicht !!
Oh das wuste ich nicht danke für den Hinweis
"Die integrierte Onboard-Chip-Grafik funktioniert nicht mit Stems 2 die Nvidia Karten der xx50-Serie sind zu schwach ist eine lowbudget Version also Finger weg.
Eine grobe Geschwindigkeiten Übersicht:
RTX 2060: 10x
RTX 2070: 12x
RTX 2080: 15x
RTX 3060: 15x
RTX 3060Ti: 20x
RTX 3070: 22x
RTX 3080: 30x
RTX 4080: 40x
Recommended min. Hardware requirements:
Windows 10 or newer
8 GB RAM or more
For Stems 2.0
geposted Sun 25 Aug 24 @ 1:24 pm
Ich nutze VDJ lediglich zum "normalen" Musik auflegen. Große Experimente mache ich als Anfänger nicht.
Wenn ich es richtig verstehe, dann kann man bei Stems z.B. die Vocals von einem Lied in ein anderes einfügen, oder?
Kann man Stems auch ausschalten?
Wenn ja, welcher Laptop wäre dann wohl geeignet?
geposted Sun 25 Aug 24 @ 1:36 pm
https://www.notebooksbilliger.de/msi+cyborg+15+a13vf+881+823688
Ja die kann man ausschalten
hier ist eine Demo zum anhören https://de.virtualdj.com/stems/
Unser Stems 2.0-Motor sorgt für außergewöhnliche Klarheit in Acapellas. Durch die Isolierung des reinen Gesangsteils des Songs kann der DJ auf ganz neue Weise kreativ sein. Alles ist über die Performance-Pads der Stems leicht zugänglich, um eine sofortige Isolierung zu gewährleisten, oder isolieren Sie den Gesang allmählich mit den Stems auf der EQ-Option.
Unsere Stems 2.0-Engine kann den Gesang genauso einfach entfernen und nur die strukturellen Teile eines Songs abspielen. Zusätzlich können Sie nur Teile des Instrumentals, wie Schlagzeug, Bass, Hi-Hat und Melodie, isolieren oder entfernen. Werden Sie kreativ auf ganz neue Weise. Die Möglichkeiten sind endlos!
Stems 2.0 ERSTKLASSIGE AUDIOTRENNUNG VirtualDJ führte bereits 2020 die Echtzeit-Stem-Trennung ein und startete diese Revolution des DJing. Seitdem hat sich der Hardware-Markt ständig weiterentwickelt und neue Möglichkeiten eröffnet, was nun mit Consumer-Laptops vernünftig gemacht werden kann. Heute verwendet VirtualDJ 2023 unsere neueste Stems 2.0-Engine, die die beste Qualität auf dem Markt für die Stammtrennung bietet, mit unglaublicher Klarheit auf Acapellas!
geposted Sun 25 Aug 24 @ 1:40 pm
Vielen lieben Dank. Das hört sich in der Tat auch super an mit den Stems. Da macht ein besserer Laptop tatsächlich mehr Sinn.
Wäre dieser geeignet?
https://www.notebooksbilliger.de/lenovo+loq+3+83fq000yge+823545
geposted Sun 25 Aug 24 @ 1:54 pm
Nein Grafikkarte: Intel Arc A530M
Der verlinkte MSI ist von Preis Leistung am besten bei NBB
oder hier ebay NBB mit Gutscheincode!
geposted Sun 25 Aug 24 @ 2:00 pm
geposted Sun 25 Aug 24 @ 2:40 pm
Der Msi ist günstiger und hat eine bessere Hardware wozu dann die Frage?
15,6" FHD 144Hz Display,
Intel Core i5-13420H der 13. Generation bieten eine leistungsfähige Hybrid-Architektur mit Leistungs- und Effizienzkernen (P- und E-Cores), kombiniert mit intelligenter Zuordnung von Workloads durch den Intel® Thread Director.
16GB RAM
512GB SSD
NVIDIA RTX 4060
Windows 11
Lenovo 15,6 Zoll Display,
Intel® Core™ i5 i5-12500H Prozessor 12. Generation älter
16 GB RAM, 512 GB SSD,
NVIDIA GeForce RTX™ 3060 älter
16GB RAM
512GB SSD
NVIDIA RTX 4060
Windows 11
geposted Sun 25 Aug 24 @ 4:27 pm
Nur für mich zum Verständnis.
Den ersten den Du mir aufgeführt hast würde dann nicht funktionieren?
geposted Sun 25 Aug 24 @ 4:43 pm
genau wegen der GeForce RTX 3050, RTX 4050 usw. wie schon geschrieben sowas kannte ich von Nvidia nicht aber man lernt immer was neues dazu. Und bei den Mindesanfoderung von VDJ steht das auch nicht drin.
metrix wrote :
"Die integrierte Onboard-Chip-Grafik funktioniert nicht mit Stems 2 die Nvidia Karten der xx50-Serie sind zu schwach eine Lowbudget Version.
geposted Sun 25 Aug 24 @ 4:45 pm
