Hi,
I'm using a Numark N4. It has 2 cinch inputs for analog things. When I want to start a record it doesn't start if the song comes from analog. What do i do wrong?
geposted Tue 27 Aug 24 @ 6:43 am
The analog inputs cannot be recorded unless the USB IN/TIMECODE switch on the back of the unit is turned on.
However, if you turn the switch on, the inputs are not audible anymore.
Finally, by default, VirtualDJ is set to wait for sound when you start a recording.
So, when you start a recording but you hear the analog sources, the program waits for sound in order to start recording (since the program doesn't listen to the analog inputs because the USB IN switch is turned off and therefore it hears silence)
geposted Tue 27 Aug 24 @ 7:40 am
Ok, thank you. I’ll try that
geposted Tue 27 Aug 24 @ 9:54 am
