I have very bad noise in the headphone.... no bass and when turn button either cue mix or cue gain nothing really happen. Try to change the gain from 0.5 to 2.0 but nothing change.
I would like to know if there is a solution or capitalization on that issue. thanks a lot regards
geposted Fri 30 Aug 24 @ 4:49 pm
