UPDATE: all sorted. Needed a reboot with the controller plugged in.
Hello. I have an akai 218. I connected it to vdj but it wont trigger the samples via physical pads. I checked the mapping and when i press on a pad, the actions trigger. I am not familiar with scripting so maybe someone here can help? Thanks.
also I have an inpulse 200 mk2 runing with it which works fine. maybe conflict?
geposted Sat 31 Aug 24 @ 5:21 am
