If I enable quantize or "auto sync on play", and start a track via the play/pause button, it beat matches properly to the currently playing track. However I start playing a track via a hotcue instead, it more often than not will not beat match, and instead just starts playing off-beat to the other track. I've tried with both "smart play" and "smart cue" enabled and disabled, but that did not seem to have any impact.
geposted Sat 31 Aug 24 @ 6:24 pm
turn on smartcue :-)
geposted Sat 31 Aug 24 @ 7:13 pm
I've tried with Smart Cue turned on, I've also tried turning on Smart Play. Neither fixed it.
geposted Sat 31 Aug 24 @ 7:19 pm
what is you HotcueMode set to?
i would try play if its on something else
also is there a controller involved?
also global quantize set to 1 beat
geposted Sat 31 Aug 24 @ 7:26 pm
HotCueMode is set to "play", and Global Quantize is set to 1. And this is happening without a controller
geposted Sat 31 Aug 24 @ 7:39 pm
