I use the latest version of Virtual DJ on an older MacBook Air (1.6 GHz Intel Core i5; 4 GB RAM; Intel HD Graphics 6000) running MacOS Mojave 10.14.6. I won't upgrade beyond Mojave as the larger OS overhead causes audio glitches when running Virtual DJ and multitasking on a machine with so little RAM.
When first opening Virtual DJ with a controller connected, the GUI glitches and flickers (as pictured). If I force close and re-open the app, it usually glitches a second time. However, it generally fixes itself the third time I start Virtual DJ.
The GUI doesn't seem to do this when there's no controller connected.
I have a similar spec MacBook Air of the same vintage and nearly the same spec (1.6 GHz Intel Core i5; 8 GB RAM; Intel HD Graphics 6000) which previously had exactly the same issue. However, I've clean installed Catalina and it no longer does. Therefore, it seems to be Mojave specific and not due to insufficient RAM, as this machine has 8 GB.
As you still officially support MacOS 10.14, any chance of a fix please?
geposted Tue 03 Sep 24 @ 9:33 pm
