Hi,
I'm using a Numark NS4FX on a Pro license and it works great, until I try to turn a mic on - then all I get is an infinite echo. I've tried different mics and nothing works on my required controller audio settings. The only time it stops is if I adjust to Seperate Decks, but then I can't use headphones to cue.
Any help would be appreciated.
geposted Fri 20 Sep 24 @ 3:00 pm
