Hi guys.
My problem is: after upgrading to build 8308 on my Pioneer DDJ-400 the cue key has lost it's previous properties. Previously if I held it for a few seconds there was no need to press the Play key to make the track play. Currently, it returns to the CUE point. How can I restore the previous setting?
Best regards
RobSzy
Best regards
RobSzy
geposted Sun 29 Sep 24 @ 10:47 am
You can map the cue button to cue_play
geposted Sun 29 Sep 24 @ 11:02 am
Ok, i will try.
Update: it works, thank you very much.
RobSzy
RobSzy
geposted Sun 29 Sep 24 @ 11:08 am
