Topic: 4 Waves - can the display be larger?
SepatroPRO InfinityMember since 2019
Hello, I started to use the 4 decks + 4 waves option - which is very convenient. However, it is hard to see the actual beats etc as those waves are very small. Is there a way to make them larger (in height)?
geposted Tue 01 Oct 24 @ 9:14 am
agadj2PRO InfinityMember since 2021
i don´t use stock skin, in other skins you can control this pararm, try skins like "project control" by @denyo for me is the best custom skin.
Regards
geposted Wed 09 Oct 24 @ 2:47 pm
I missed this, there is a skin or two that allows wave resizing., one of the projectX skins I think.
If you want a stock skin modifying I do that kind of thing, a few beers in return for the favour.
I do have this one ready to go that somebody requested, default pro 4 decks full everything
as you see there's no browser space, it uses a popup window for the browser
geposted Wed 09 Oct 24 @ 5:46 pm
