I Have different controllers I use but when I use The DDj-REV-7 some how it turns the Key_lock off after unhook it some times my SZ-2 & Rev-1 & Sx-2 work ok.. so I mapped on ONINIT key_lock on but it will not come on when open VDJ,the tab has been remove aLONG time ago but i need 2 make sure it on with out using a custom tab
geposted Fri 04 Oct 24 @ 9:09 am
Could you please try to explain what you mean in a better way ?
I have a really hard time trying to understand you.
All I understand is that you have a problem with DDJ-REV7 that sometimes turns off the key_lock.
REV7 should NOT turn off key_lock by it's own.
However, REV7 has several means of changing the key of a track (that your other controllers don't)
Like dedicated KEY+ and KEY- buttons, that can also be used with SHIFT to match or reset the key of a track.
So, a better explanation (try to be as clear as possible) will help us understand your issue and help you.
geposted Fri 04 Oct 24 @ 9:58 am
is key_lock set to auto on now?
geposted Wed 09 Oct 24 @ 11:48 pm
