Hi! I recently purchased an impulse 500 and I would love to use it with virtual dj but I really don’t like how the effects work. For example when enabling an effect, the filter cannot be used. I was wondering if anyone has mapping that I would be able to download for the controller or maybe could suggest a way that I would be able to map it myself. Thanks so much!
geposted Thu 10 Oct 24 @ 5:51 pm
That's just a colorFX and that's how they work, the buttons can be remapped, but before doing that you should look at the "inp pad fx" padpage [shift+M2]
https://virtualdj.com/manuals/hardware/hercules/inpulse500/pads.html
geposted Thu 10 Oct 24 @ 6:17 pm
